How does everyone analyze a problem where cold forming has changed the material properties in certain areas.
Example:
Geometry: A simple "L" bracket cold bent from flat steel.
Loads: Turn 45 lke a "V" and pull apart like <- V ->
Properties: ???, The material propties will be different where the forming has taken place, in the notch of the "L"
Results: If I use uniform material property of the material before forming it will effect the deformation. Also if the yield strength is increased it will effect the yield criteria.
EngForm78
Example:
EngForm78
