electricpete
We are installing a Bendix coupling in place of gear coupling in a turbine-driven pump application at or plant.
I am not directly involved, but did have a chance to talk it over with the responsible engineer and it brought up some interesting aspects that I wasn't familiar with.
The turbine and pump have thrust bearings. An axial resonant frequency was calculated under assumption that both shafts are fixed and the coupling mass moves on it's own springiness (diagrpham) between them. If each half has stiffness K, the total stiffness of SDOF model would be K/2 since it is connected to "ground" on both sides.
Quasi-physical model:
Ground ===K===Mass===K===Ground
SDOF Model
Ground ===K/2===Mass
The resonant frequency of the coupling as calculated above falls within the operating speed range. But it is not considered a problem because:
1 - There is not a lot of axial excitation at running speed to be found. (open to comment.. I'm thinking misalignment may create an axial forcing function)
2 - The coupling is axially flexible and for low levels of forces and deflections (far below any endurance limits) it enters the non-linear region of the "spring" (diaphram). Apparently a stiffening spring creates a classic response vs frequency profile shaped like a shark's fin (with the pointy part of the fin pointing toward higher frequencies for stiffening spring and lower frequencis for softening spring). Mechanial Vibration's by Rao discusses this in terms of Duffing's equation. Den Hartog also discusses it in a simpler way.
I can see the shape of this non-linear system response curve is much different than a linear resonant SDOF system and I can see the idea of "resonance" doesn't apply to this non-linear SDOF in exactly the same way as a linear system. I can't particularly judge how effective it is in limiting max vibration magnitude for a system with only structural damping (no fluid or elastomeric damping).
Above is a lot of new concepts for me, I'd be interested in any comments. In particular:
Can anyone provide discussion or link of ability of non-linear spring to limit max vib amplitude for a given forcing function magnitude, variable frequency?
If this is an effective means to limit vibration magnitude, why isn't it used more often or discussed within "vibration control" section of textbooks?
(2B)+(2B)' ?
SDOF Model
(2B)+(2B)' ?
