Non perpindicular holes
apb
I am a (very) recent convert to SW from long use of Mechanical Desktop and can not figure out how to do the following
The part is a 3"OD x .25 wall x 12" long tube.
The tube has a horizontal and vertical plane along the axis
I want to put a threaded hole in the tube, perpendicular to the long axis of the tube and parallel to the horizontal plane, offset about 1/2" above the horizontal plane.
The hole wizard seems to understand threaded holes normal to the surface of the tube. I have not been able to make it do holes that are non perpendicular to the surface of the tube.
What am I missing?
You may have to create a plane on the surface at whatever angle you want the hole axis to be. Apply your hole wizard hole to that plane.
As a last resort you can always not use hole wizard and just cut a hole in the tube at the non-perpendicular angle.
I ended up using an offset plane, I was just hoping there was an easier way
What could be easier than making an offset plane?
[cheers] from (the City of) Barrie, Ontario.
[ponder] If you choke a smurf, [smurf] what color does it turn?
Hey .... now that's just "plane" lazy Tick [lol]
FYI - True Helical Threads will cause Performance loss. It's better to fake it rather than make them.
I have a downloadable bolt at my site on threads. Check out the different Configurations.
Scott Baugh, CSWP [borg2]
faq731-376
