koenigsegg
Hi all,
I'm currently trying to run a nonlinear static analysis of an engine mount using this simplified 3D geometry:
The material model is assumed to be a linear elastic one with a Young's Modulus of 2.5 MPa and a Poisson ratio of 0.45 (I'm using hybrid linear elements to prevent the problems related to the almost incompressible behavior of the material).
Although the fact that I've tried several material properties and analysis controls, I've not been able to achieve a complete analysis (there are frequent negative eigenvalues warnings and the analysis fails due to a excessively small "time" increment being used).
A curious aspect is the fact that the analysis always stops in the same deformed position:
(Please note that I've removed all contact interactions in order to simplify the model)
Does anyone have any idea for what might be wrong?
Thanks in advance,
koenigsegg
Thanks in advance,
koenigsegg
