nonlinear analysis. Large Deflection in a aluminium sheet
Gwenda
Materials
May 14, 2009
5
Hello everyone:
I have a problem with a nonlinear analisis.
I have a aluminium sheet, with a small thick, that is someted a pressure at the top. Also I have the curve stress vs strain.
I want to obtain the stresses and deformations of the sheet, but, when I do the Solve, the program doesn´t finish.
I think, that is because, I must put the pressure by increments, but I don´t know how to do it well.
I asked every people I know, who works with ansys,but a few people, works with nonlinear analysis, so I need help.
What does it do when it exits from the solve? Does it give any kind of error message?
Are you working in classic or workbench?
For large deflection use the command NLGEOM,ON in /solu. It will basically reposition the direction of the external loads after deflection and re-iterate.
Hi!!
It do nothing, doesnt finish the graphic, for that I supposed that the problem is with the pressure.
In the file ERROR, I have a lot of warnings. I send you one of the file and you can see them, because I´m doing many tests, trying to obtain the solution.
Now I´m trying to do it, dividing the load in 10 steps.
Ahhh I´m working with classic, no workbench
 http://files.engineering.com/getfile.aspx?folder=34da7c47-b3cc-4cd3-a04a-74c0ed464cbe&file=alfonso¦s_foam_1.1.err
Thanks timKwan! I go to do this now.
I thought in some errors in the constrains, but I dont know where, and also maybe, in the calculations about strain and stress...
But first, I´ll try with this tutorial, Thank you very much.
