Nonlinear compressuion connector
Shervin34
Bioengineer
Jun 26, 2007
Please let me know what kind of options I have to purchase a nonlinear connector? Conical springs might be an option, however, I am more interested in a rod shape compression spring that has a variable rate.
Shervin
Thanks for your reply and I appreciate your help as online material is confusing and inconclusive!
I am interested in a connector that behaves such as a hardening sping. As it deflects more, rates increases. In addition, there is geometrical limitations. Maximum OD is 0.5" and minimum ID is 0.2". Force is about 70-80 lb. Relaxed length is about 0.2 " .
So, there are couple of questions:
1) Generally, What kind of connectors can provide this behavior?
2) To design a nonlinear conical compression spring, how can I define the spring parameters? Does each coil have to fit into the next coil?
3) Is there any rod shape non-linear compression spring (equal ODs at both ends) available ? e.g. made of rubber, or polymer?
Thank you in advance
Shervin
1. Why do you refer to it as a connector?
2. Physically you will not be able to get 70-80 lb from such a small spring made of coiled wire or strip.
3. A conical spring where each coil fit into the next coil will have a linear behavior.
4. You didn't give the spring deflection to get the 70-80 lb force.
5. When you say "relaxed length" do you mean the free length when the spring is not loaded?
I think you should check your design and see if you can free more space.
If you can give more information on the application it may help.
Belleville springs doesn't have a progressive rate increase behavior. They have very limited deflection so you will need a stack of them to get the deflection you need. I do not believe you can get 70-80 lb from a 0.5" spring and if you can the deflection will be very small I assume ~0.02" and a linear behavior.
Why are you avoiding giving more information? This goes nowhere and there is not much point to continue this thread.
Well I think that his lack of response indicates this is a dead subject...
