Normalized eigenvectors
aeromecha
4
Does anyone know how the eigenvectors are normalized in cyclic symmetry analysis of ANSYS 7.0?
By the way, I found the following information in ANSYS website.
In modal cyclic symmetry, this becomes even more complicated because of the presence of the duplicate sector. Here the mass normalization is [ [phi]a~ [M] [phi]a + [phi]b~ [M] [phi]b =1]. When two sectors are used, the scaling factor of sqrt(1/2) is still valid, but it should be applied on the magnitude: i.e, sqrt (real**2+imaginary**2).
......When I conduct this calculation, I can't get the unit matrix. Please let me know if you're familier with this.
Tommy
In ANSYS, the eigenvector normalisation is controlled by the MODOPT command:
MODOPT, Method, NMODE, FREQB, FREQE, PRMODE, Nrmkey
The Nrmkey controls this normalisation by using either
OFF — Normalize the mode shapes to the mass matrix (default).
ON — Normalize the mode shapes to unity instead of to the mass matrix. If a subsequent spectrum or mode superposition analysis is planned, the mode shapes should be normalized to the mass matrix (that is, Nrmkey = OFF).
So by default, these are normalised to the mass matrix. To get the these normalised to unity, use Normkey = on, or go to:
Main Menu>Preprocessor>Loads>Analysis Type>Analysis Options
Main Menu>Solution>Analysis Type>Analysis Options
See faq569-1083 for details on how to make best use of Eng-Tips.com
Drej,
Thank you for your response.
Yes, I turned off the MODOPT option.
Then, I get mode shapes in real and imaginary form. (for basic and duplicate sector).
My question is how I can compute the unit matrix using those mode shapes and mass matrix of the basic sector.
Tommy
