Grashopr
- Nov 25, 2004
- 4
I am completing a project that requires me to substitute one type of automotive-style sensor for a completely different automotive-style sensor (a Throttle-Position-Sensor for a Pressure(boost) Sensor) The output voltage of the Pressure Sensor is read by the ECU, and ranges from 2.0 to 5.0v, but the output of the TPS under normal circumstances is 0v to 1v. Would a switching regulator take the voltage from the Boost Sensor and produce an output voltage similar to the TPS? I really appreciate any help you all can give me. If any part of this doesnt make sence, or if you need more information, just let me know. Thanks!
Phil
grashopr@mchsi.com
Phil
grashopr@mchsi.com
