sathish kumar dhanasekaran
Petroleum
- Apr 6, 2020
- 6
can you anyone explain the below paragraph i cannot understand this paragraph ..my question is what is the meaning of this content(PQR for a process record-
ing a test coupon that was at least 1/2 in. (13 mm) thick)
(b) For GTAW, SMAW, GMAW, PAW, and SAW, or com-
binations of these processes, a PQR for a process record-
may be combined with one or more other PQRs recording
another welding process and any greater base metal
thickness. In this case, the process recorded on the first
PQR may be used to deposit the root layers using the pro-
cess(es) recorded on that PQR up to 2t (for short‐
circuiting type of GMAW, see QW-404.32) in thickness
on base metal of the maximum thickness qualified by
the other PQR(s) used to support the WPS. The require-
ments of Note (1) of Tables QW-451.1 and QW-451.2 shall
apply.
apply.
