Dear all,
I have mechanically cyclic loads (axial, bending, torsion and shear from a rotating agitator) acting simultaneously at a nozzle. The design cycles are specified. (10ex9)
(1) shall the fatigue analysis be done by calculating stress (by FEA) from each load case, find out its cycles from fatigue curve, then use Accumulated Fatigue Damage per Eq 5.46 to sum up all 4 load cases ? or
(2) just run stress analysis with all loads acting simultaneously, then find out the cycles and compared with the design cycles ?
The vendor uses (1), but I don't think that is correct because it ignores the stress tensor. It assumes stress generated by each load case is acting in the same direction, although that is the worst scenario to sum everything up positively. However, when all 4 loads acting simultaneously, the maximum stress intensity may be reduced due to stress tensor that stress subtraction occurs.
