Nozzle opening limitations per EN13445
XL83NL,
Yes, the requirement comes from EN 13445 part 5, annex C.
Is there any alternate rule by which code allows this configuration?
Thanks in advance!
Raai2015,
It's not like that the configuration is failing in terms of thickness or reinforcement. It is easily passed.
The only concern is limitations on opening
r6155,
Didn't get your question.
Vessel and nozzle diameters are mentioned in first post above, i.e. manhole (DN600) on a vessel (ID 1000 mm)
Two question to better understand your situation;
- what’s the vessel’s length?
- does table C.3-1 provide any alternative options, like a head hole?
Huub
