JStephen
- Aug 25, 2004
- 8,686
A couple of quick questions on nozzle reinforcement in a formed head per ASME B&PV Section VIII:
If I understand UG-37 right, when a nozzle is not radial in the head, then the dimension "d" is the chord across the nozzle, rather than the nozzle diameter. Is this correct? The definition seems to indicate this, but none of the illustrations in either ASME or the vessel books I have actually show this.
In UG-40, the limits of reinforcement are described as being measured "parallel to a vessel wall". For a curved head, does this mean it is an arc measurement along the head or just an offset distance from the nozzle centerline?
