We have replaced an existing centrifugal pump impeller. the new impeller Head Curve is already plotted on the original manufacturers pump curve.
However only one NPSH required Curve has been drawn on the Pump Curve.
If the pump impeller is changed would the NPSHreq not change as well. from the curve it implies that a single curve is applicable to a number of impellers(with different diameters).
Can the affinity laws be used to determine the NPSHreq curve? (h1/h2) = (d1/d2)^2 - for constant speed.
or does the manufacturer have to retest the pump to provide a new NPSH req curve?
The question is how do i get an NPSHreq curve for the other impeller diameter?
can someone point me in the right direction.
