Hopefully somebody could correct me here as I must be doing something wrong. The suction pressure on this vertical pump is 106psig and the vapour pressure is 100psig. The suction pressure was taken off of the centrifugal pump datasheet. Subtracting the vapour pressure from the suction pressure, which I assume takes into account the loss from the pipes and fittings and is the actual pressure going into the pump, 106-100=6psid which is equivalent to 18ft of head, given the S.G. of the fluid is 0.77.
Is it fair to say the NPSHA is 18ft? Reason why I ask is, when the end user was queried on the NPSHA, they said it was only 3ft but confirmed the pressure values they provided were correct???
How so? Also, question#2..is it possible to be have the vapour pressure very close to the suction pressure but still not cavitate as the NPSHA>NPSHR?
