brendanpeach
Hi
I'm currently modelling a train track insulated joint bar with abaqus and i can't fix a problem i keep encountering. The job keeps re-attempting the first increment of the first step because of problems.
The model consists of two rail sections with and end post in the middle and two 6 hole joint bars bolted across the join. The rail sections have tie constraints to the end post. I've experimented with the joint bar interactions and have found that i seem to get more progress with the joint bars tied to the rail face rather than a no friction contact. the joint bars and rail all have interactions with the 6 bolts, no gaps exist between the bolts and the bolt holes. the bolts are currently modelled as deformable parts with the normal properties of steel.
The warnings i get are along these lines:
***WARNING: SOLVER PROBLEM. NUMERICAL SINGULARITY WHEN PROCESSING ELEMENT
BOLT2.1 D.O.F. 1 RATIO = 3.08682E+011.
***WARNING: THE SYSTEM MATRIX HAS 27 NEGATIVE EIGENVALUES.
CONTACT PAIR (ASSEMBLY__PICKEDSURF618,"ASSEMBLY_NEG BAR HOLE 5") NODE
BOLT5.229 IS OVERCLOSED BY 3.32517 WHICH IS TOO SEVERE.
***NOTE: SEVERE CONTACT OVERCLOSURES EXIST. CONVERGENCE IS JUDGED UNLIKELY.
As you can see the problem seems to be with the bolts. with the numerical singularity problems i am getting problems with D.O.F 1,2 and 3.
Any help would be appreciated.
