nutplate pitch
britcan
Aerospace
Mar 10, 2005
5
does anyone know the part number of a MS or NAS(M)type nut plate that has a 0.75" pitch between the rivet holes
nutplace diameter is 10-32 or 3/16
thank you
that sounds pretty big, and no doubt you've looked yourself and not found anything. could you make your own, by mounting a standard a/nut on a small piece of sheet ?
I looked thru all the nutplate specs I have and only found .688 max. This is MS21059 and several others that have similar numbers (ms21060, etc).
Hmmm, .688 MAX pitch for an MS21059? I've pitched them quite a bit farther after pryng them out of some unreachable area of an aircraft and being rewarded with a couple of bloody knuckles.>:-<
Yes, but the pitch could be .688 Kilometers.
Thanks for the assistance
We are going to use a nut plate doubler similsr to one of the ides posted below
How do you pitch the rivets further than the .688 inch pitch manufactured in the nutplate? Maybe you have a nutplate stretcher?? haha
you'd attach the nutplates (maybe the one-legged variety) onto a strip of sheet stock, and attach that "somehow" to the plane ... no stretch marks involved
rb1957...
I prefer cutting-out and using a 1-nut section of a gang-channel nutplate. ED should probably be at least 0.2... so overal length is ~1.16"(+) [0.58" X 2].
Regards, Wil Taylor
