NX 10 right click radial shortcut icon in front of application 2
BOPdesigner
434
I had a strange thing happen in NX 10, I switched to full screen mode and the icon to switch back was missing, but I eventually figured out how to get back. In the process, some how this rectangular array icon appeared on my workspace and I can't figure out how to dismiss it. When you click on it the same functions as the right click and hold radial shortcut popup icons appear. Any ideas?
 http://files.engineering.com/getfile.aspx?folder=72bf1b26-017f-47a4-ba7d-a8bed9848098&file=permanent_shortcut.png
You can try to select another role and see if everything falls back in place.
I think you switched into the touch/tablet-panel role as that icon shows up in that role and I haven't figured out how to even move it out of the way.
HTH,
Ryan
Ryan Gudorf
CAD/CAM Supervisor
Budde Sheet Metal Works, Inc.
Windows 7 Professional x64 SP1
Solid Edge V20
NX10.0.2.6
TC10 in Testing
32 GB RAM, nVIDIA Quadro K4200
Hi
This icon means the touch screen mode is activated. There should be a hand-looking icon somewhere in the quick-access toolbar. Click on it to deactivate the touch mode. (Search "Touch mode" in the command finder if you can't find it)
2JL
