NX 11: Snapping to angled holes on a pipe
Huhu3
1
I would like to know if there is a smart way to snap to angled holes on a pipe?
I have found a way to work around this by adding points in the right coordinates but if the positions of the holes are changed, the section line will not be updated.
Best regards,
Huhu
 https://files.engineering.com/getfile.aspx?folder=6facbcdc-6129-40e7-a50e-8ced7e329a9c&file=AngledHolesOnPipe.png
Is your problem that the section line does not stay associated to the hole on the drawing, if the hole is moved ?
Jerry J.
UGV5-NX1961
