NX 2212: Subtraction error....... 2
CAD2015
Computer
Jan 21, 2006
2,048
This is a very simple operation and never had this problem.
I created a tube using extrusion of a sketch circle:
The subtract tool doesn't perform. There is just a shadow of the operation, without cutting.
Where am I wrong?
Thank you!
Perhaps you have inadvertently chosen "intersection" instead of "subtract"?
If not, try giving the cutting extrusion some length in the -Y direction so that it does not start on the same plane as the tube.
If it still does not work, try examine geometry to look for issues.
Thanks, Cowski.
I had the same initial thought before; I double checked, I chosen to subtract.
It almost looks like you have two solid bodies. Try using delete body and see how many Solid Bodies you have. Kind of cool issue. ugh.
Try changing the boolean option to "none" then try to subtract in a separate step at the end. This might give you a more verbose error message if/when something goes wrong with the subtract.
