I am a longtime I-DEAS user now using NX 7.5. In I-DEAS, I was able to animate a constrained engine assembly (crankcase, crankshaft, rods and pistons) by adding an angular constraint to the crankshaft and using it as the driving dimension. I have been trying to animate an engine assembly in NX using assembly sequencing but I’m experiencing some difficulties.
I constrained the assembly so that I can use Assemblies -> Component Position -> Move Component… on the crankshaft and it is free to rotate, moving the other components along with it as you would expect. I go to Assemblies -> Sequence…, choose Insert -> Motion and select the crankshaft. I move the handles to the crankshaft center and choose the appropriate handle to move for the rotation. I set it to have 36 frames and type in 360° for the angle and hit enter. The crankshaft rotates but the connecting rods stay fixed in the same position as they also rotate 360° around with the crankshaft. The pistons stay in the cylinders and do not move. I don’t understand how the connecting rods can break away from the pistons if they are constrained to each other. Has anybody experienced something like this? Is there a solution?
I’d like to add that a co-worker was able to make this work in NX 7.0 before the upgrade to NX 7.5. Also, I know you can do things like this in Motion Simulation but I do not have a license for it.
NX 7.5.4.4
Teamcenter 8 (8.3.3.3_n01.1)
NX 7.5.4.4
