NX 9 Creating Flexible hose Assemblies
civancic
Industrial
Jul 18, 2014
4
I just tried to create a flexible hose assembly in NX 9 routing with a locked length. I could not get the ends to move as desired. If I tried to re-orient an end it was rotating the entire assembly. If I removed locked length it would move as desired. Another problem that I am having is that I can not set an extension length on a port in NX 9. If I went back to NX 7.5 and created with a locked length the ends would move as expected. If I opened the hose assembly created in NX 7.5 in NX 9 the ends would move as expected. But whenever I try to create a new assembly in NX 9 I cannot get the desired movement of the fitting in the hose assembly. I think it might have something to do with the specify vector selection but am not sure.
I am thinking of doing a video on this.
The first thing is the NX version.
NX9.0.2.5
It worked in NX8.5 but broke in NX9.0
I do have a video showing using the flex pipe function but not one on how to make the component.
Using the component is at the end of the video.
Peter Crookall
Snr Application Specialist
PhoenxPLM
