NX CAE: How to Heal a Failed Node
justinheckman
16
I'm running NX 8.5 Advanced Simulation:
I've meshed my body and ran an Element Quality check to find failed nodes. It resulted in 2 failed nodes, but I don't know the proper workflow to heal these failed nodes.
Clearly I'm new to CAE, so any help would be great!
Thanks all
- Justin Heckman
Dear Justin,
Well, when you run a Mesh Quality check you are looking for elements (not nodes) that failed because the element distortion is bigger than the maximum quality threshold values required by the FEA solver.
In general (depending of the failed check: Aspect Ratio, Skew Angle, Jacobian, etc ..) the way to improve the mesh quality is reducing the element size, while at the same time to simplify the geometry.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: Blog de FEMAP & NX Nastran:
Thank you, this helps me to understand.
- Justin Heckman
