Khaledtr
Automotive
- Sep 4, 2022
- 3
Hi Everyone,
I'm using NX 12 and I face some issue with attributes ;
1st thing : I created a custom template model and a custom template drawing and I assigned attributed for each, the problem that when I create the drawing before assign a material to the model the drawing doesn't read the attribute and material cell in title block doesn't make the update to show the assigned material. Is there any way to solve this ?
2nd thing : that I'm using the template drawing for parts & assembly and I'd make an attribute for mass in title block ; if it's a part it show its mass (It works) and if it's an assembly it show the sum of the mass of parts in the assembly, is it possible ?
last point that if I'm going to make a drawing for assembly I'd that Material cell shows a string like "Composite" or "Various" ... .
Thanks in advance
Thanks in advance
