NX error (Unsuitable OM object)
pegus
Aerospace
Mar 18, 2015
67
Good day,
I am using NX10. I have the following issue when I try to open a part, it display the following error message "An operation was attempted on an invalid or unsuitable OM object". The only way to open it is load it as "structure only" with partial loading.
After I activate all the components in the assembly, I noticed that the promote bodies that are in the part navigator are not updated, and due to this, none of the features are being reflected neither.
When I try to synchronize the links of the promote bodies, I get the same error message.
Have you face this issue? if so, can you please help me to solve it?
P.P.
Have you tried turning the partial loading off, then open your assembly?
