NX Journal Body rename to STEP export
MilesvdL
Marine/Ocean
GB
I have a problem that I would like to automate somehow, but not sure how to do it.
My current workflow is as follows,
1 - export assembly outside teamcenter
2 - you will need to define a naming rule "${db_Part_name} which will use the part name instead of the item ID.
3 - Open a standalone version of UG.
4 - read in the exported assembly.
5 - export a STEP file of the assembly.
You will now have a STEP file of the assembly which will retain the part names when you read it into another CAD/CAM package. If that software supports assembly structure.
Similar to this thread, thread561-316531.
Not being a programmer is there a way to create a journal or similar that will rename the solid bodies in an assembly so I can skip the need to export from teamcenter and just export a STEP where the bodies are all now named ${db_Part_name} for example.
I hope that makes sense.
Thanks,
Miles
You can simply export a STEP file from a model file in TeamCenter to your filesystem.
FILE -> EXPORT -> STEP
Jerry J.
UGV5-NX1961
Thank you Jerry,
The problem is the renaming of the bodies in the assembly.
We could manually do this as shown in the image but I would like a way to rename the bodies for all parts in the assembly.
