NX Journal- Get measurement result in delta X, Y, and Z 1
nxexplorer
84
Hi all,
When measuring the overall size of mold assy in nx 9.0,I have an Idea to specify 2- points diagonal of longest distance of mold assy, then it will get delta x, y and z. Restore it as attributes then shows results of delta x, delta y and deta z in writeline.
Any suggest on how to do that, is very much appreciated.
Best Regards,
Maryadi
Do you want to select those two points in graphical window (or) Do you want modify/Edit the journal each time to input the point names?
Please see below C# code, it will calculate the delta X,Y and Z of 2 given points. Point names should be "PT1" and "PT2".
using System;
using NXOpen;
namespace Dist_Points
public class Dist_Chk
public static void Main(string[] args)
Session theSession = Session.GetSession();
UI theUi = UI.GetUI();
Part workPart = theSession.Parts.Work;
ListingWindow lw = theSession.ListingWindow;
String pnt1_name = "PT1";//Rename this to point 1
String pnt2_name = "PT2";//rename this to Point 2
Double[] ord = new Double[6];
bool pnt1s = false;
bool pnt2s = false;
try
PointCollection pts = workPart.Points;
lw.Open();
foreach (Point p in pts)
if (p.Name == pnt1_name)
ord[0] = p.Coordinates.X;
ord[1] = p.Coordinates.Y;
ord[2] = p.Coordinates.Z;
pnt1s = true;
else if(p.Name == pnt2_name)
ord[3] = p.Coordinates.X;
ord[4] = p.Coordinates.Y;
ord[5] = p.Coordinates.Z;
pnt2s = true;
if (pnt1s != true || pnt2s != true)
theUi.NXMessageBox.Show("Point Distance tool", NXMessageBox.DialogType.Information, "Points names are not correct");
lw.WriteFullline("Distance in X: "+(ord[0]- ord[3]).ToString());
lw.WriteFullline("Distance in Y: " + (ord[1] - ord[4]).ToString());
lw.WriteFullline("Distance in Z: " + (ord[2] - ord[5]).ToString());
catch (Exception ex)
theUi.NXMessageBox.Show("Point tool", NXMessageBox.DialogType.Error, ex.ToString());
public static int GetUnloadOption(string dummy) { return (int)NXOpen.Session.LibraryUnloadOption.Immediately; }
Hi Ram K
Thank you for the journal. Its what I need,I have renamed both two points with PT1 and PT2 but still fail, seems like the points names are not identified." Points names are not correct"
Maryadi
Hi Maryadi,
When renaming , Please set the selection filter to Point and select the points. In your case point features are renamed instead of point object.
Attached image is for reference.
Hi Ram K
Ok, let me give it a try, one more.
Maryadi
Hi Ram K,
Yes, Perfect. It's work.
Thank you.
Maryadi
Here is modified journal from above codes, maybe someone needs it in future.
First point to be given a name "1"
Second point to be given a name "2"
Now, I have an Idea to select both two points without doing manual naming, which is mean it will auto-naming to "1" and "2",. Any help is very much appreciated.
using NXOpen;
using System;
String pnt1_name = "1";//Rename this to point 1
String pnt2_name = "2";//rename this to Point 2
bool pnt1s = false;
bool pnt2s = false;
try
lw.Open();
pnt1s = true;
pnt2s = true;
double DeltaX = (Math.Abs(ord[0]- ord[3]));
double DeltaY = (Math.Abs(ord[1]- ord[4]));
double DeltaZ = (Math.Abs(ord[2]- ord[5]));
string DX=DeltaX.ToString("n2");
string DY=DeltaY.ToString("n2");
string DZ=DeltaZ.ToString("n2");
string titleStr = "MOLDSIZE";
string msize = DX+" x "+DY+" x "+DZ;
workPart.SetUserAttribute( titleStr,-1, msize, Update.Option.Now );
lw.WriteFullline( titleStr +": " +msize);
Maryadi
