NX Journal - Move CSYS to layer, but skip CSYS on layer 2
StianA
NO
I'm new to journaling and have a question I hope you can help me with. I found this code online, which moves CSYS to a specific layer:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.Features
Imports NXOpen.Utilities
Imports NXOpen.UF
Module ChangeDatums
Sub Main()
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim ufs As UFSession = UFSession.GetUFSession()
Dim lw As ListingWindow = theSession.ListingWindow
Const Layno As Integer = 41
For Each myFeature As Feature In workPart.Features
If TypeOf (myFeature) Is DatumCsys Then
'uncomment the following If block to skip internal features
'If myFeature.IsInternal Then
' Continue For
'End If
Dim csys_tag As Tag
Dim origin_tag As Tag
Dim daxes As Tag()
Dim dplanes As Tag()
ufs.Modl.AskDatumCsysComponents(myFeature.Tag, csys_tag, origin_tag, daxes, dplanes)
ufs.Obj.SetLayer(origin_tag, Layno)
ufs.Obj.SetLayer(csys_tag, Layno)
For Each thisObj As NXOpen.Tag In daxes
ufs.Obj.SetLayer(thisObj, Layno)
Next
For Each thisObj As NXOpen.Tag In dplanes
Next
End If
Next
End Sub
End Module
I would like to add something to this code so that it skips any CSYS that already was placed on layer two. Similar to what this script is doing with sketches:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module ChangeDatums
Sub Main()
Const SketchLayer As Integer = 22
Dim i As Integer = 0
'move sketches
For Each sketchObj As Sketch In workPart.Sketches
'skip internal sketches
If sketchObj.IsInternal Then
Continue For
End If
'skip sketches on layer 2
If sketchObj.Layer = 2 Then
Continue For
End If
sketchObj.Activate(False)
sketchObj.Layer = SketchLayer + i
sketchObj.RedisplayObject()
sketchObj.Deactivate(False, Sketch.UpdateLevel.SketchOnly)
i += 1
Next
'Update layers by turning on and off layer 22
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")
theSession.SetUndoMarkName(markId1, "Layer Settings Dialog")
Dim stateArray1(0) As Layer.StateInfo
stateArray1(0).Layer = 22
stateArray1(0).State = Layer.State.Selectable
workPart.Layers.ChangeStates(stateArray1, False)
Dim stateArray2(0) As Layer.StateInfo
stateArray2(0).Layer = 22
stateArray2(0).State = Layer.State.Hidden
workPart.Layers.ChangeStates(stateArray2, False)
theSession.SetUndoMarkName(markId1, "Layer Settings")
theSession.DeleteUndoMark(markId1, Nothing)
End Sub
End Module
In the last script this is what makes it skip layer 2:
Continue For
End If
Do any of you have a suggestion for how I could add something similar to the first script?
(I don't really understand what the "tag"-stuff is about, maybe someone could shine some light on that as well?) Thank you!
I'm currently on NX6, but moving to 8.5 soon, if that matters.
BR
Stian LA
Code:
Option Strict Off
Imports System
Imports NXOpen
Module Module2
    Sub Main()
        Const newLayer As Integer = 41
        Const skipLayer As Integer = 2
        For Each myFeature As Feature In workPart.Features.GetFeatures()
                'uncomment following If block to skip internal features
                '    Continue For
                'End If
                Dim DBuilder As DatumCsysBuilder
                DBuilder = workPart.Features.CreateDatumCsysBuilder(myFeature)
                Dim DCObj() As NXObject = DBuilder.GetCommittedObjects
                For Each temp As DisplayableObject In DCObj
                    If temp.Layer = skipLayer Then
                        'terminate the for loop
                        Exit For
                    End If
                    temp.Layer = newLayer
                    temp.RedisplayObject()
                Next
                DBuilder.Destroy()
                Dim updateMark As Session.UndoMarkId
                updateMark = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "update")
                Try
                    theSession.UpdateManager.LogForUpdate(myFeature)
                    theSession.UpdateManager.DoUpdate(updateMark)
                Catch ex As Exception
                End Try
            End If
        Next
    End Sub
End Module
www.nxjournaling.com
Dear Cowski,
What is an internal feature? How is relative to the part navigator tree?
Thank you.
Thanks a lot for the quick reply, cowski!
I've just tested the script and I get this error message:
Line 42: 'LogForUpdate' is not a member of 'NXopen.Update'
Do you know how to fix this?
BR
Stian LA
Hasten the move the NX 8.5 [smile]
For NX 6, you could try commenting out that line; I don't have NX 6 installed to test with, so I can't guarantee that that will fix the problem and everything will run fine...
For an example of an internal feature, start the "extrude" command. In the "select curve" prompt, hit the sketch icon and create a sketch. Finish the sketch and enter values for the extrude. When you press OK, the extrude is created, but the sketch does not show up in the part navigator, even though it is a full fledged feature. The sketch has been made "internal" to the extrude feature.
Thanks a lot, Cowski! That works perfectly in NX 8.5:)
