NX Journal needed To copy attribute
Altojoe
New member
Mar 16, 2013
23
TO copy a attribute of a Part (For Example say callout) to a clipboard in following format <W!xxxxx@CALLOUT>
Try this code (will not work with NX 8 or higher).
Code:
'NXJournaling.com
'October 29, 2014
'select component, copy attribute reference string to clipboard
'NX 7.5 and below only!
Option Strict Off
Imports System
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        If IsNothing(theSession.Parts.Work) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Const undoMarkName As String = "NXJ journal"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, undoMarkName)
        Dim myComponent As Assemblies.Component
        If SelectComponent("Select component", myComponent) = Selection.Response.Cancel Then
            Return
        End If
        '$$$ specify attribute title to get from component
        Const myAttrTitle As String = "CALLOUT"
        Dim myAttrValue As String
        Dim output As String
        Try
            myAttrValue = myComponent.GetStringAttribute(myAttrTitle)
            output = "<W!" & myComponent.Tag.ToString & "@" & myAttrTitle & ">"
            Clipboard.SetText(output)
        Catch ex As NXException
            If ex.ErrorCode = 512008 Then
                'attribute not found
                MessageBox.Show("Attribute '" & myAttrTitle & "' not found, journal exiting", "Attribute not found", MessageBoxButtons.OK, MessageBoxIcon.Error)
                Return
            Else
                theSession.UndoToMark(markId1, undoMarkName)
                MessageBox.Show(ex.Message, "Error: " & ex.ErrorCode, MessageBoxButtons.OK, MessageBoxIcon.Error)
            End If
        Finally
        End Try
        lw.Close()
    End Sub
    Function SelectComponent(ByVal prompt As String, ByRef selObj As NXObject) As Selection.Response
        Dim theUI As UI = UI.GetUI
        Dim title As String = "Select a component"
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim cursor As Point3d
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
        Dim selectionMask_array(0) As Selection.MaskTriple
        With selectionMask_array(0)
            .Type = UFConstants.UF_component_type
            .Subtype = UFConstants.UF_all_subtype
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectObject(prompt, _
         title, scope, selAction, _
         includeFeatures, keepHighlighted, selectionMask_array, _
         selobj, cursor)
        If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
        '----Other unload options-------
        'Unloads the image immediately after execution within NX
        'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
        'Unloads the image explicitly, via an unload dialog
        'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly
    End Function
End Module
www.nxjournaling.com
