nx journal to create Index number at dimension with adjusted orientation
cschnei
Industrial
DE
I am trying to create an Index number to a selected dimension. For this I found a very helpful journal in this forum that I modified a bit. Now I need to adjust the text angle of the ID Symbol to match the diminsion's orientation. Dimensions do not have a lettering angle in the style dialog like notes. Therefore I wanted to use the TextOrienationAngle from the dimension.
But I allways get an error:
"Line 56: "GetDimensionPreferences" is not a member of "NXOpen.Annotations.Annotation"
Code:
'journal to Create Non- Associative Index Numbers at Dimensions or Notes
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Imports NXOpen.Annotations
Module NXJournal
Sub Main
'change the following offset distances to get something that works for you
'offsets from dimension text
Const XOffsetDim as Double = 0
Const YOffsetDim as Double = 2
'offsets from notes
Const XOffsetNote as Double = -3
Const YOffsetNote as Double = 0
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim lw As ListingWindow = theSession.ListingWindow
Dim noteDim As Annotation
Dim noteDimOrigin as Point3D = Nothing
Dim letterPref as LetteringPreferences = Nothing
Dim symbolPref as SymbolPreferences = Nothing
Dim dimpref as DimensionPreferences = Nothing
Dim noteNumber as Integer
Dim letterangle as String
Dim dimangle as String
Dim input as String
Dim theAnnotationManager as NXOpen.Annotations.AnnotationManager = workPart.Annotations
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")
Do
	input = InputBox("Enter starting INDEX number: ", "Create Index Numbers at Dimensions or Notes", "")
Loop Until (isNumeric(input))
noteNumber = input
lw.Open()
While selectNoteDimension("Select Dimension or Note", noteDim) = Selection.Response.Ok
	noteDimOrigin = noteDim.AnnotationOrigin
	'lw.WriteLine("origin: " & noteDimOrigin.X & ", " & noteDimOrigin.Y)
	letterPref = noteDim.GetLetteringPreferences()
	letterangle = letterPref.Angle
	dimpref = noteDim.GetDimensionPreferences()
	dimangle = dimpref.TextOrienationAngle
	'symbolPref = NXOpen.Preferences.AnnotationPreferences.GetSymbolPreferences()
	symbolPref = theAnnotationManager.Preferences.GetSymbolPreferences()
	'lw.WriteLine("Alignment Position: " & letterPref.AlignmentPosition.ToString())
	'lw.WriteLine("ID Symbol size: " & symbolPref.IDSymbolSize)
	'lw.WriteLine("Annotation type: " & noteDim.GetType().ToString())
	Dim nullAnnotations_IdSymbol As Annotations.IdSymbol = Nothing
	Dim idSymbolBuilder1 As Annotations.IdSymbolBuilder
	idSymbolBuilder1 = workPart.Annotations.IdSymbols.CreateIdSymbolBuilder(nullAnnotations_IdSymbol)
	idSymbolBuilder1.Origin.Plane.PlaneMethod = Annotations.PlaneBuilder.PlaneMethodType.XyPlane
	idSymbolBuilder1.Type = Annotations.IdSymbolBuilder.SymbolTypes.Circle
	idSymbolBuilder1.UpperText = noteNumber
	'use the symbol size set in the part
	idSymbolBuilder1.Size = 4
	idSymbolBuilder1.Style.LetteringStyle.GeneralTextSize = 2.5
	idSymbolBuilder1.Style.LetteringStyle.Angle = dimangle
	Dim assocOrigin1 As Annotations.Annotation.AssociativeOriginData
	Dim nullPoint As Point = Nothing
	Dim nullView As View = Nothing
	With assocOrigin1
		.OriginType = Annotations.AssociativeOriginType.OffsetFromText
		.OffsetAnnotation = noteDim
		.OffsetAlignmentPosition = Annotations.AlignmentPosition.TopRight
		.AssociatedPoint = nullPoint
		.StackAlignmentPosition = Annotations.StackAlignmentPosition.Above
		.AlignedAnnotation = Nothing
		if noteDim.GetType().ToString() = "NXOpen.Annotations.Note" Then
			.XOffsetFactor = XOffsetNote
			.YOffsetFactor = YOffsetNote
		Else
			.XOffsetFactor = XOffsetDim
			.YOffsetFactor = YOffsetDim
		End if
	End With
	Dim point1 As Point3d = New Point3d(noteDimOrigin.X-4, noteDimOrigin.Y+6, 0.0)
	'idSymbolBuilder1.Origin.SetInferRelativeToGeometry(True)
	'idSymbolBuilder1.Origin.SetAssociativeOrigin(assocOrigin1)
	idSymbolBuilder1.Origin.Origin.SetValue(Nothing, nullView, point1)
	Dim QC_IDSymbol As IDSymbol
	QC_IDSymbol = idSymbolBuilder1.Commit()
	'change IDSymbol layer to match that of the dimension or note it is attached to
	QC_IDSymbol.Layer = 109
	idSymbolBuilder1.Destroy()
	noteNumber += 1
End While
lw.Close
theSession.SetUndoMarkName(markId1, "Label Dimensions")
theSession.SetUndoMarkVisibility(markId1, Nothing, Session.MarkVisibility.Visible)
End Sub 'Main
    Function selectNoteDimension(ByVal prompt As String, ByRef obj As Annotation)
	'Annotation class covers dimensions and notes
	'Annotation -> Dimension
	'Annotation -> DraftingAid -> SimpleDraftingAid -> NoteBase -> BaseNote -> Note
        Dim ui As UI = GetUI()
        Dim mask(1) As Selection.MaskTriple
        With mask(0)
            .Type = UFConstants.UF_dimension_type
            .Subtype = 0
            .SolidBodySubtype = 0
        End With
		With mask(1)
            .Type = UFConstants.UF_drafting_entity_type
            .Subtype = UFConstants.UF_draft_note_subtype
        End With
        Dim cursor As Point3d = Nothing
        Dim resp As Selection.Response = _
        ui.SelectionManager.SelectObject(prompt, prompt, _
            Selection.SelectionScope.AnyInAssembly, _
            Selection.SelectionAction.ClearAndEnableSpecific, _
            False, False, mask, obj, cursor)
        If resp = Selection.Response.ObjectSelected Or _
           resp = Selection.Response.ObjectSelectedByName Then
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function	'selectNoteDimension
End Module
Can anyone help me on this problem?
CSchnei
Not guaranteed to solve all your problems, but should get you past your current hurdle:
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Module Module18
    Sub Main()
        Const XOffsetDim As Double = 0
        Const YOffsetDim As Double = 2
        'offsets from notes
        Const XOffsetNote As Double = -3
        Const YOffsetNote As Double = 0
        Dim noteDimOrigin As Point3d = Nothing
        Dim letterPref As LetteringPreferences = Nothing
        Dim symbolPref As SymbolPreferences = Nothing
        Dim dimpref As DimensionPreferences = Nothing
        Dim noteNumber As Integer
        Dim letterangle As [highlight #FCE94F]Double[/highlight]
        Dim dimangle As [highlight #FCE94F]Double[/highlight]
        Dim input As String
        Dim theAnnotationManager As NXOpen.Annotations.AnnotationManager = workPart.Annotations
        [highlight #FCE94F]Dim idTextAngle As Double[/highlight]
        Do
        Loop Until (IsNumeric(input))
        noteNumber = input
        lw.Open()
[highlight #FCE94F]            If TypeOf (noteDim) Is Annotations.Note Then
                'code for notes
                'lw.WriteLine("note: " & noteDim.GetType.ToString)
                idTextAngle = letterangle
            Else
                'code for dims
                'lw.WriteLine("dim: " & noteDim.GetType.ToString)
                Dim theDim As Dimension = noteDim
                dimpref = theDim.GetDimensionPreferences()
                idTextAngle = dimangle
            End If[/highlight]
            idSymbolBuilder1.Style.LetteringStyle.Angle = [highlight #FCE94F]idTextAngle[/highlight]
            With assocOrigin1
                If noteDim.GetType().ToString() = "NXOpen.Annotations.Note" Then
                Else
                End If
            End With
            Dim point1 As Point3d = New Point3d(noteDimOrigin.X - 4, noteDimOrigin.Y + 6, 0.0)
            Dim QC_IDSymbol As IdSymbol
            noteNumber += 1
        End While
        lw.Close()
    End Sub 'Main
        With mask(0)
            .Subtype = 0
        End With
        With mask(1)
        End With
        Else
        End If
End Module
www.nxjournaling.com
That's exactly what I need, thanks a lot.
cschnei
