Nx Journaling - Get Full path of Selected component 1
Kumaresh_07
Automotive
IN
hi all,
I would like to write a code for Getting Full path of Selected component.
It would be nice if you guys could help me.
Now i have code for user component selection. but i don't know how to get that selected component directory.
Code:
Option Explicit Off
Option Infer On
Imports NXOpen
Imports System
Imports NXOpen.UF
Module NXJournal
    Sub Main()
        Dim theSession = NXOpen.Session.GetSession()
        Dim workPart As NXOpen.Part = theSession.Parts.Work
        Dim displayPart As NXOpen.Part = theSession.Parts.Display
        Dim theUI As UI = UI.GetUI
        Dim title As String = "Select the component"
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim cursor As Point3d
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
        Dim selectionMask_array(0) As Selection.MaskTriple
        With selectionMask_array(0)
            .Type = UFConstants.UF_component_type
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _
         title, scope, selAction, _
         includeFeatures, keepHighlighted, selectionMask_array, _
         selobj, cursor)
    End Sub
End Module
Try this:
Code:
Option Explicit Off
Option Infer On
Imports NXOpen
Imports System
Imports NXOpen.UF
Module NXJournal
    Sub Main()
	Dim prtName As String
	Dim prtNameAndPath As String
	Dim lw As ListingWindow = theSession.ListingWindow
	lw.open()
        End With
         selobj, cursor)
	If response = Selection.Response.Cancel Or response = Selection.Response.Back Then
		Return
	End If
	lw.writeline(selobj.OwningPart.FullPath)
	lw.close()
    End Sub
End Module
With best regards
Michael
Wow.. It works in perfect manner.
Thanks Michael.
