Hi all,
When I try to replace a component from the assembly by the same component "saved as" with new name, and with "retain relation" checked, the component gets replaced and both of its relations (contact csys over csys) are effectively retained.
When I try to do the same with a component exactly build like the original, one of the constraints (still CSYS over CSYS) is broken.
I thought the UID was the problem, but even if I set UID of the new component to match the original, it still break the constraint while replacing.
The parts are generated with a vb macro, so they really are the same.
Any idea why this behavior ? Is there another hidden UID attribute ?
Thanks for any help
Sun
NX12
EDIT : I'm not sure I put this topic in the right section :/ pardon me.
Thanks for any help
Sun
NX12
