bulldogbaja
Automotive
- Sep 24, 2013
- 2
I am using Nastran NX 8.0. I'm using the MAT8 card to input 2D properties for a unidirectional CF. The material properties I have specify different tensile and compression modulus and Poisson's ratio. My load case is complex so bending is impossible to predict.
Is there a way to input different tensile and compression properties? If not, what is the preferred method of selecting which material property values to use?
