NX Open: WinForm + Mask Select Body
Patrick1234
CA
I have a technical question. I'd like to validate a point before spending too much time trying to find a solution.
I'm currently working on a small application (on VS2019 in VB .net) to export Parasolid using a WinForm interface.
1-In journaling: open the application (WinForm interface with 1 button “Select Button”)
2-Click on the selection button: Clicking on the selection button calls a “Selection.MaskTriple” function. While the function is active, the WinForm window should become background.
3-Select a component on the screen. I want to select a component in the screen and retrieve the Tag of this component and its attributes...then I'll do other things with this information.
4-Exit the “Selection.MaskTriple” function and return the WinForm window to the foreground.
So in Journaling, my application is displayed correctly from NX. When I click on my button, I call a “Selection.MaskTriple” function and the NX selection window appears correctly. However, the focus remains on the Winform window and although I see the “Selection.MaskTriple” window, it's inaccessible and I can't select any items in the NX assembly or in the NX window.
My question is, is it possible to pair a Winform Interface and a ''Selection.MaskTriple'' function with NX's little selection box? I want to know if I'm wasting my time with this approach.
If you tell me that it's possible to combine the two, I'll look into the matter further... because I've been trying a lot of things for two days now and haven't found a solution yet.
Best Ragards!
Patrick
I found this code that almost does the job.
Is it possible to have “Form1” displayed again after the items have been selected?
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module1
Public TheSession As Session = Session.GetSession()
Public TheUI As UI = UI.GetUI()
Public TheUFSession As UFSession = UFSession.GetUFSession()
Public ufs As NXOpen.UF.UFSession = NXOpen.UF.UFSession.GetUFSession()
Sub Main(ByVal args() As String)
Dim workPart As Part = TheSession.Parts.Work
Dim lw As ListingWindow = TheSession.ListingWindow
If IsNothing(TheSession.Parts.Work) Then
'active part required
Return
End If
lw.Open()
Echo("PTS-0")
Dim theForm As New Form1()
theForm.ShowDialog()
Echo("PTS-1")
If theForm.DialogResult = System.Windows.Forms.DialogResult.Cancel Then
MsgBox("User pressed 'Cancel', exit journal")
Return
End If
'MsgBox("continue journal code in Sub Main()")
Dim selectionMask() As Selection.MaskTriple = Nothing
BuildSelectionMask(selectionMask, theForm.chkFaces.Checked, theForm.chkCurves.Checked)
Dim userSelectedObjects() As TaggedObject = Nothing
If SelectObjects(selectionMask, userSelectedObjects) = Selection.Response.Cancel Then
Echo("object selection canceled")
Return
End If
Echo("Options selected:")
Echo("Select Solids: " & theForm.chkSolids.Checked.ToString)
Echo("Select Faces: " & theForm.chkFaces.Checked.ToString)
Echo("Select Curves: " & theForm.chkCurves.Checked.ToString)
Echo("")
Echo(userSelectedObjects.Length.ToString & " object(s) selected")
For Each temp As TaggedObject In userSelectedObjects
Echo("object type: " & temp.GetType.ToString)
Echo("object tag: " & temp.Tag.ToString)
Echo("")
Next
lw.Close()
End Sub
Function SelectObjects(ByVal selMask() As Selection.MaskTriple, ByRef selObj() As TaggedObject) As Selection.Response
Dim theUI As UI = UI.GetUI
Dim prompt As String = "Select Objects"
Dim title As String = "Selection"
Dim includeFeatures As Boolean = False
Dim keepHighlighted As Boolean = False
Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
Dim scope As Selection.SelectionScope = UFConstants.UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY 'Selection.SelectionScope.WorkPart
Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt, title, scope, selAction, includeFeatures, keepHighlighted, selMask, selObj)
If resp = Selection.Response.Ok Then
Return Selection.Response.Ok
Else
Return Selection.Response.Cancel
End If
End Function
Sub BuildSelectionMask(ByRef maskArray() As Selection.MaskTriple, ByVal faces As Boolean, ByVal curves As Boolean)
Dim theSelectionMasks As New List(Of Selection.MaskTriple)
Dim newSelMask As Selection.MaskTriple
With newSelMask
.Type = UFConstants.UF_solid_type
.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
End With
theSelectionMasks.Add(newSelMask)
If faces Then
newSelMask.Type = UFConstants.UF_solid_type
newSelMask.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_ANY_FACE
End If
If curves Then
newSelMask.Type = UFConstants.UF_line_type
newSelMask.Subtype = UFConstants.UF_line_normal_subtype
newSelMask.Type = UFConstants.UF_circle_type
newSelMask.Subtype = UFConstants.UF_all_subtype
newSelMask.Type = UFConstants.UF_conic_type
newSelMask.Type = UFConstants.UF_spline_type
End If
maskArray = theSelectionMasks.ToArray
End Sub
'FUNCTION: Echo
Public Function Echo(ByVal output As String)
TheSession.ListingWindow.Open()
TheSession.ListingWindow.WriteLine(output)
TheSession.LogFile.WriteLine(output)
End Function
Public Function GetUnloadOption(ByVal dummy As String) As Integer
' Unloads the image immediately after execution within NX
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
Public Class Form1
Private Sub Form1_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load
End Sub
Private Sub Button2_Click(sender As System.Object, e As System.EventArgs) Handles Button2.Click
Me.DialogResult = System.Windows.Forms.DialogResult.Cancel
Me.Close()
End Sub
Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
Me.DialogResult = System.Windows.Forms.DialogResult.OK
Me.Close()
End Sub
End Class
'Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()>
Partial Class Form1
Inherits System.Windows.Forms.Form
#Region " Windows Form Designer generated code "
Public Sub New()
MyBase.New()
'This call is required by the Windows Form Designer.
InitializeComponent()
End Sub
'Form overrides dispose to clean up the component list.
Protected Overrides Sub Dispose(ByVal disposing As Boolean)
Try
If disposing AndAlso components IsNot Nothing Then
components.Dispose()
End If
Finally
MyBase.Dispose(disposing)
End Try
End Sub
'Required by the Windows Form Designer
Private components As System.ComponentModel.IContainer
'NOTE: The following procedure is required by the Windows Form Designer
'It can be modified using the Windows Form Designer.
'Do not modify it using the code editor.
Friend WithEvents GroupBox1 As System.Windows.Forms.GroupBox
Friend WithEvents chkCurves As System.Windows.Forms.CheckBox
Friend WithEvents chkFaces As System.Windows.Forms.CheckBox
Friend WithEvents chkSolids As System.Windows.Forms.CheckBox
Friend WithEvents Button1 As System.Windows.Forms.Button
Friend WithEvents Button2 As System.Windows.Forms.Button
'Private Sub InitializeComponent()
<System.Diagnostics.DebuggerStepThrough()> Private Sub InitializeComponent()
'Dim resources As System.ComponentModel.ComponentResourceManager = New System.ComponentModel.ComponentResourceManager(GetType(Form_NXOpen_Template))
Me.GroupBox1 = New System.Windows.Forms.GroupBox()
Me.chkCurves = New System.Windows.Forms.CheckBox()
Me.chkFaces = New System.Windows.Forms.CheckBox()
Me.chkSolids = New System.Windows.Forms.CheckBox()
Me.Button1 = New System.Windows.Forms.Button()
Me.Button2 = New System.Windows.Forms.Button()
Me.GroupBox1.SuspendLayout()
Me.SuspendLayout()
'GroupBox1
Me.GroupBox1.Controls.Add(Me.chkCurves)
Me.GroupBox1.Controls.Add(Me.chkFaces)
Me.GroupBox1.Controls.Add(Me.chkSolids)
Me.GroupBox1.Location = New System.Drawing.Point(12, 26)
Me.GroupBox1.Name = "GroupBox1"
Me.GroupBox1.Size = New System.Drawing.Size(260, 118)
Me.GroupBox1.TabIndex = 0
Me.GroupBox1.TabStop = False
Me.GroupBox1.Text = "Selection Options"
'chkCurves
Me.chkCurves.AutoSize = True
Me.chkCurves.Location = New System.Drawing.Point(22, 76)
Me.chkCurves.Name = "chkCurves"
Me.chkCurves.Size = New System.Drawing.Size(59, 17)
Me.chkCurves.TabIndex = 2
Me.chkCurves.Text = "Curves"
Me.chkCurves.UseVisualStyleBackColor = True
'chkFaces
Me.chkFaces.AutoSize = True
Me.chkFaces.Location = New System.Drawing.Point(22, 53)
Me.chkFaces.Name = "chkFaces"
Me.chkFaces.Size = New System.Drawing.Size(55, 17)
Me.chkFaces.TabIndex = 1
Me.chkFaces.Text = "Faces"
Me.chkFaces.UseVisualStyleBackColor = True
'chkSolids
Me.chkSolids.AutoSize = True
Me.chkSolids.Checked = True
Me.chkSolids.CheckState = System.Windows.Forms.CheckState.Checked
Me.chkSolids.Enabled = False
Me.chkSolids.Location = New System.Drawing.Point(22, 30)
Me.chkSolids.Name = "chkSolids"
Me.chkSolids.Size = New System.Drawing.Size(54, 17)
Me.chkSolids.TabIndex = 0
Me.chkSolids.Text = "Solids"
Me.chkSolids.UseVisualStyleBackColor = True
'Button1
Me.Button1.Location = New System.Drawing.Point(12, 165)
Me.Button1.Name = "Button1"
Me.Button1.Size = New System.Drawing.Size(84, 34)
Me.Button1.TabIndex = 1
Me.Button1.Text = "Select Objects"
Me.Button1.UseVisualStyleBackColor = True
'Button2
Me.Button2.DialogResult = System.Windows.Forms.DialogResult.Cancel
Me.Button2.Location = New System.Drawing.Point(188, 165)
Me.Button2.Name = "Button2"
Me.Button2.Size = New System.Drawing.Size(84, 34)
Me.Button2.TabIndex = 2
Me.Button2.Text = "Cancel"
Me.Button2.UseVisualStyleBackColor = True
'Form1
Me.AcceptButton = Me.Button1
Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!)
Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
Me.CancelButton = Me.Button2
Me.ClientSize = New System.Drawing.Size(284, 218)
Me.Controls.Add(Me.Button2)
Me.Controls.Add(Me.Button1)
Me.Controls.Add(Me.GroupBox1)
Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.Fixed3D
Me.MaximizeBox = False
Me.MinimizeBox = False
Me.Name = "Form1"
Me.Text = "Form1"
Me.GroupBox1.ResumeLayout(False)
Me.GroupBox1.PerformLayout()
Me.ResumeLayout(False)
End Sub
#End Region
End Class
End Module
Add "theForm.ShowDialog()" near the end of sub Main to show the dialog again after the selection. Note that you will also need to add code to handle the dialog cancel event.
www.nxjournaling.com
