NX Render - Ground Settings Unavailable
Mirza98
Marine/Ocean
Feb 10, 2024
11
When in Render Mode with Advanced Studio active, why are the Ground Settings in Scene Preferences completely greyed out? I even created a fresh new part and extruded a cube, the ground settings are still not available. I got it to work on one existing assembly but I could not figure out the reason.
What NX version ?
-This setting has "moved around" with the NX versions. In 2312 it's not that easy to find.
Tomas
The more you know about a subject, the more you know how little you know about that subject.
Thank you for your reply,
I am running 2312.
Dumb question maybe, do you have the license ?
Tomas
I just tested, if i load a model, turn on "Studio Display" and then Open Scene Preferences, the ground settings are greyed out.
But , if i select a system Scene from the Resource bar and after that open the Scene preferences, it's "live".
Tomas
Thank you Tomas, I also see it active after going into Advanced Studio and selecting one of the pre-made scenes from the Resource Bar.
