NX routing in manage mode >> setup 2
lklo
Industrial
Nov 24, 2010
226
Hi -
Just a stort question...
Can someone confirm , that the PTB & PLV files shall be uploaded in a specific dataset in teamcenter , if routing standard parts is located in teamcenter as well....
And afterwards some environment variables should point to these item's, which contains the datasets with PTB & PLB files....
Regards lklo....
Nope. You can store them on central server location and set the UGII_ROUTE_MECH_KIT_DIR variable to point to that location.
Code:
UGII_ROUTE_MECH_KIT_DIR=##Your Server Location##
UGII_EPLIB_PART_LIB_VIEW_PATH=${UGII_ROUTE_MECH_KIT_DIR}\appview
UGII_ROUTE_MECH_APP_VIEW=${UGII_ROUTE_MECH_KIT_DIR}\appview\ugroute_mech_metric.xml
UGII_EPLIB_TABLE_PATH=${UGII_ROUTE_MECH_KIT_DIR}\metric\tables
UGII_ROUTE_MECH_PART_PATH=${UGII_ROUTE_MECH_KIT_DIR}\metric\parts
UGII_ROUTE_BEND_TABLES_PATH=${UGII_ROUTE_MECH_KIT_DIR}\metric\tables
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
HI NutAce -
thank you very much...
I just tried today - and it works very well in manage mode, as well...
Though, I faced some issues regarding the attributes from part family' member into the PTB file...
Not sure which exactly attributes should be part of the PTB files - but I will play with some different combinations.
 http://files.engineering.com/getfile.aspx?folder=8bd05abe-a80d-4a28-b8bf-4e2f43c781b4&file=ptb.JPG
