NX VB Journal Reference Dimensions
beng021228
I'm using NX6, but a solution in NX7.5 or nx8 is just as good. Is there a way to "look at" modeling sketch reference dimensions programatically? I can "see" the driving dimensions just fine, but I need to analyze the dimensions I set as reference as well. I was thinking that UFsession might get me there, but so far has gotten me nowhere. Here is the code I have in that vein:
Do
ufs.Obj.CycleObjsInPart(parttag, UFConstants.UF_dimension_type, objtag)
If objtag <> NXOpen.Tag.Null Then
ReDim Preserve thetags(j)
thetags(j) = objtag
j = j + 1
End If
Loop While objtag <> NXOpen.Tag.Null
Thanks for any tips or suggestions you have.
I was thinking maybe instead of collecting the reference dimensions, that I could collect a measurement of the same geometry instead, but again I'm not sure how I would access a measurement, or collection of measurements.
For the driving dimensions I was using this:
newarray = workpart.Expressions.ToArray()
Dim expindex As Integer = newarray.Length-1
ReDim dimexpression(expindex)
Dim exparms(expindex)
Dim k As Integer
For k = 0 To expindex
dimexpression(k) = workpart.Expressions.GetVisibleExpressions.GetValue(k)
Next
Now I notice that if I convert a dimension to reference, it is still grabbed by this, but when I change the values of the driving dimensions the reference dimension that is grabbed by the code is not updated, and when viewing the expresions (tools>expressions) it is not updated. However if I manually convert the ref sketch dimension to driving and then back again it updates the value. This might get me what I need if there is a way to programatically see if a dimension is set to reference, convert it and convert it back again.
I was in the middle of writing about my disappointment in this only grabbing driving dimensions from the sketch, but.. it only grabs driving dimensions from the sketch! So I can compare the list this gets me to the list I get from the expressions to determine which dimensions are reference. The only issue now is getting those values to refresh. I've been banging my head against this for months now, but this is the furthest I've gotten, thanks alot!
Here's the new code for looking at the sketch dimensions:
Dim dimnums As Integer
Dim dimtags(0) As Tag
Do
ufs.Obj.CycleObjsInPart(parttag, UFConstants.UF_sketch_type, objtag)
thetags(j) = objtag
ufs.Sket.AskDimensionsOfSketch(objtag, dimnums, dimtags)
'error checking to see what we're grabbing
MsgBox(j.ToString & " " & objtag.ToString & " " & dimnums.tostring)
j = j + 1
End If
The msgbox kick out the number 29 in my error checking model for the number of dimensions, there are 35 in the sketch with 4 of those being reference, so if the index starts at 0 that works out right.
Actually, this is more what I had in mind:
Code:
[COLOR=blue]Option[/color] [COLOR=blue]Strict[/color] [COLOR=blue]Off[/color]
[COLOR=blue]Imports[/color] System
[COLOR=blue]Imports[/color] NXOpen
[COLOR=blue]Imports[/color] NXOpen.UI
[COLOR=blue]Imports[/color] NXOpen.Utilities
[COLOR=blue]Imports[/color] NXOpen.UF
[COLOR=blue]Module[/color] select_a_sketch_module
    [COLOR=blue]Dim[/color] s [COLOR=blue]As[/color] Session [COLOR=blue]=[/color] Session.GetSession()
    [COLOR=blue]Dim[/color] ufs [COLOR=blue]As[/color] UFSession [COLOR=blue]=[/color] UFSession.GetUFSession()
    [COLOR=blue]Sub[/color] Main()
        [COLOR=blue]Dim[/color] sketch [COLOR=blue]As[/color] Tag
        [COLOR=blue]Dim[/color] sketchDims() [COLOR=blue]As[/color] Tag
        [COLOR=blue]Dim[/color] numDims [COLOR=blue]As[/color] [COLOR=blue]Integer[/color]
        [COLOR=blue]Dim[/color] lw [COLOR=blue]As[/color] ListingWindow [COLOR=blue]=[/color] s.ListingWindow
        lw.Open()
        [COLOR=blue]While[/color] select_a_sketch(sketch) [COLOR=blue]=[/color] Selection.Response.Ok
 [COLOR=green]'MsgBox("sketch Tag:" & sketch.ToString())[/color]
            ufs.Disp.SetHighlight(sketch, 0)
            ufs.Sket.AskDimensionsOfSketch(sketch, numDims, sketchDims)
 [COLOR=green]'MsgBox("number of dimensions: " & numDims)[/color]
            [COLOR=blue]Dim[/color] expTag [COLOR=blue]As[/color] Tag
            [COLOR=blue]Dim[/color] expString [COLOR=blue]As[/color] [COLOR=blue]String[/color]
            [COLOR=blue]Dim[/color] expValue [COLOR=blue]As[/color] [COLOR=blue]Double[/color]
            [COLOR=blue]Dim[/color] dimStatus [COLOR=blue]As[/color] [COLOR=blue]Integer[/color]
            [COLOR=blue]Dim[/color] refDim [COLOR=blue]As[/color] Annotations.Dimension
            [COLOR=blue]Dim[/color] mainText() [COLOR=blue]As[/color] [COLOR=blue]String[/color]
            [COLOR=blue]Dim[/color] dualText() [COLOR=blue]As[/color] [COLOR=blue]String[/color]
            [COLOR=blue]For[/color] [COLOR=blue]Each[/color] dimTag [COLOR=blue]As[/color] Tag [COLOR=blue]In[/color] sketchDims
                ufs.Sket.AskDimStatus(dimTag, expTag, expString, expValue, dimStatus)
[COLOR=blue]If[/color] dimStatus [COLOR=blue]=[/color] 1 [COLOR=blue]Then[/color]  [COLOR=green]'reference dimension[/color]
                    refDim [COLOR=blue]=[/color] Utilities.NXObjectManager.Get(dimTag)
                    refDim.GetDimensionText(mainText, dualText)
                    lw.WriteLine("Reference dimension: " [COLOR=blue]&[/color] mainText(0))
                [COLOR=blue]Else[/color]
                    lw.WriteLine("Active dimension: " [COLOR=blue]&[/color] expString)
                End [COLOR=blue]If[/color]
            [COLOR=blue]Next[/color]
        End [COLOR=blue]While[/color]
    End [COLOR=blue]Sub[/color]
    [COLOR=blue]Function[/color] select_a_sketch(ByRef sketch [COLOR=blue]As[/color] NXOpen.Tag) [COLOR=blue]As[/color] Selection.Response
        [COLOR=blue]Dim[/color] message [COLOR=blue]As[/color] [COLOR=blue]String[/color]
        [COLOR=blue]Dim[/color] title [COLOR=blue]As[/color] [COLOR=blue]String[/color] [COLOR=blue]=[/color] "Select a sketch"
        [COLOR=blue]Dim[/color] scope [COLOR=blue]As[/color] [COLOR=blue]Integer[/color] [COLOR=blue]=[/color] UFConstants.UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY
        [COLOR=blue]Dim[/color] response [COLOR=blue]As[/color] [COLOR=blue]Integer[/color]
        [COLOR=blue]Dim[/color] obj [COLOR=blue]As[/color] NXOpen.Tag
        [COLOR=blue]Dim[/color] view [COLOR=blue]As[/color] NXOpen.Tag
        [COLOR=blue]Dim[/color] cursor(2) [COLOR=blue]As[/color] [COLOR=blue]Double[/color]
        [COLOR=blue]Dim[/color] mask_sketch [COLOR=blue]As[/color] UFUi.SelInitFnT [COLOR=blue]=[/color] [COLOR=blue]AddressOf[/color] mask_for_sketchs
        ufs.Ui.LockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
        [COLOR=blue]Try[/color]
            ufs.Ui.SelectWithSingleDialog(message, title, scope, mask_sketch, _
                         Nothing, response, sketch, cursor, view)
        [COLOR=blue]Finally[/color]
            ufs.Ui.UnlockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
        End [COLOR=blue]Try[/color]
        [COLOR=blue]If[/color] response <> UFConstants.UF_UI_OBJECT_SELECTED [COLOR=blue]And[/color] _
           response <> UFConstants.UF_UI_OBJECT_SELECTED_BY_NAME [COLOR=blue]Then[/color]
            [COLOR=blue]Return[/color] Selection.Response.Cancel
            [COLOR=blue]Return[/color] Selection.Response.Ok
    End [COLOR=blue]Function[/color]
    [COLOR=blue]Function[/color] mask_for_sketchs(ByVal select_ [COLOR=blue]As[/color] IntPtr, _
                           [COLOR=blue]ByVal[/color] userdata [COLOR=blue]As[/color] IntPtr) [COLOR=blue]As[/color] [COLOR=blue]Integer[/color]
        [COLOR=blue]Dim[/color] num_triples [COLOR=blue]As[/color] [COLOR=blue]Integer[/color] [COLOR=blue]=[/color] 1
        [COLOR=blue]Dim[/color] mask_triples(0) [COLOR=blue]As[/color] UFUi.Mask
        mask_triples(0).object_type [COLOR=blue]=[/color] UFConstants.UF_sketch_type
        ufs.Ui.SetSelMask(select_, _
                           UFUi.SelMaskAction.SelMaskClearAndEnableSpecific, _
                           num_triples, mask_triples)
        [COLOR=blue]Return[/color] UFConstants.UF_UI_SEL_SUCCESS
    [COLOR=blue]Public[/color] [COLOR=blue]Function[/color] GetUnloadOption(ByVal dummy [COLOR=blue]As[/color] [COLOR=blue]String[/color]) [COLOR=blue]As[/color] [COLOR=blue]Integer[/color]
        GetUnloadOption [COLOR=blue]=[/color] UFConstants.UF_UNLOAD_IMMEDIATELY
End [COLOR=blue]Module[/color]
The sketch selection code was taken from a GTAC example, the rest of the code inside the while loop is mine.
Cool, I ran your code with the line uncommented out that displayed what numdims was grabbing and it says the same thing as mine, so it shows that I can't use numdims as an index number when cycling through all the dimensions, your way is better for that, but it shows that I'm on the right track. My code will cycle through each sketch and now I know how to cycle through each dimension in each sketch. Thank you so much.
I take back the counting thing. The number grabbed by dimnums is 100% correct and includes the reference dimensions. I was counting the out of sketch dimensions (chamfer sizes, extrude distance).
Run my code and select a sketch that has both reference and driving dimensions, it will report (via the listing window) whether the dimension is active or reference along with the current value. Is this not what you were looking for?
Yeah, but this is part of a bigger project, you gave me what I was looking for, thank you so much.
