NX11 - Attribute VB Code Help 1
Kenja824
Automotive
I have the below code someone had given me in the past to add attributes to a file.
Could someone please explain how to adjust this so that all of the attributes are added to a category? Say give the Category the name "CONTROLS" for whatever it is worth.
So that when someone opens the file properties, there will be a new category named "CONTROLS" and all of these attributes would be inside of that category.
Dim TheSession As Session = Session.GetSession()
Dim theUfSession As UFSession = UFSession.GetUFSession()
Dim WorkPart As Part = TheSession.Parts.Work
Sub Main(ByVal args() As String)
' Public Sub Initialize()
For Each KP As KeyValuePair(Of String, String) In Attributes
If Not TheSession.Parts.Work.HasUserAttribute(KP.Key, NXObject.AttributeType.Any, -1) Then
TheSession.Parts.Work.SetUserAttribute(KP.Key, -1, KP.Value, Update.Option.Now)
TheSession.ListingWindow.Open()
TheSession.ListingWindow.WriteFullline(String.Format("Creating / Writing Attribute: {0} = {1}", KP.Key, KP.Value))
End If
Next
End Sub
Public ReadOnly Property Attributes As Dictionary(Of String, String)
Get
Dim Dict As New Dictionary(Of String, String)
Dict.Add("Build Source", "")
Dict.Add("Checked By", "")
Dict.Add("Checked Date", "")
Dict.Add("Consumable", "")
Dict.Add("Customer", "")
Dict.Add("Designed By", "")
Dict.Add("Detail Number", "")
Dict.Add("FCA Detail Number", "")
Dict.Add("FCA NPM Code", "")
Dict.Add("FCA Plant Name", "")
Dict.Add("FCA Tool Number (Opposite)", "")
Dict.Add("FCA Tool Number (Shown)", "")
Dict.Add("Job Number", "")
Dict.Add("Line Assy Name", "")
Dict.Add("Line Assy Number", "")
Dict.Add("Manufacturer Name", "")
Dict.Add("Manufacturer Part Number", "")
Dict.Add("Model Year", "")
Dict.Add("NX_ObjectMaterial", "")
Dict.Add("OPP QTY", "")
Dict.Add("Paint Code", "")
Dict.Add("Program", "")
Return Dict
End Get
End Property
End Module
Code:
Option Strict Off
Imports System
Imports System.Text.RegularExpressions
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module kenja_attribute
    Dim theSession As Session = Session.GetSession()
    Dim WorkPart As Part = theSession.Parts.Work
            If Not theSession.Parts.Work.HasUserAttribute(KP.Key, NXObject.AttributeType.Any, -1) Then
                'theSession.Parts.Work.SetUserAttribute(KP.Key, -1, KP.Value, Update.Option.Now)
                AddPartStringAttribute(theSession.Parts.Work, KP.Key, KP.Value,, "CONTROLS",)
                theSession.ListingWindow.Open()
                theSession.ListingWindow.WriteFullline(String.Format("Creating / Writing Attribute: {0} = {1}", KP.Key, KP.Value))
            End If
        Next
    End Sub
    Sub AddPartStringAttribute(ByVal thePart As Part,
                               ByVal attributeTitle As String,
                               ByVal attributeValue As String,
                               Optional index As Integer = -1,
                               Optional category As String = "",
                               Optional refstring As String = "")
        Dim id1 As NXOpen.Session.UndoMarkId
        id1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "add attribute")
        Dim attributePropertiesBuilder1 As NXOpen.AttributePropertiesBuilder
        attributePropertiesBuilder1 = theSession.AttributeManager.CreateAttributePropertiesBuilder(thePart, {thePart}, NXOpen.AttributePropertiesBuilder.OperationType.None)
        If Not String.IsNullOrEmpty(category) Then
            attributePropertiesBuilder1.Category = category
        End If
        If refstring = "" Then
            attributePropertiesBuilder1.IsReferenceType = False
            attributePropertiesBuilder1.StringValue = attributeValue
        Else
            attributePropertiesBuilder1.IsReferenceType = True
            Dim expression1 As NXOpen.Expression
            expression1 = thePart.Expressions.CreateSystemExpressionFromReferenceString(refstring)
            attributePropertiesBuilder1.Expression = expression1
        End If
        If index = -1 Then
            attributePropertiesBuilder1.IsArray = False
        Else
            attributePropertiesBuilder1.IsArray = True
            attributePropertiesBuilder1.ArrayIndex = index
        End If
        attributePropertiesBuilder1.DataType = NXOpen.AttributePropertiesBaseBuilder.DataTypeOptions.String
        attributePropertiesBuilder1.Title = attributeTitle
        Dim nXObject1 As NXOpen.NXObject
        nXObject1 = attributePropertiesBuilder1.Commit()
        Dim nErrs1 As Integer
        nErrs1 = theSession.UpdateManager.DoUpdate(id1)
        attributePropertiesBuilder1.Destroy()
        theSession.DeleteUndoMark(id1, Nothing)
    End Sub
        Get
            Return Dict
        End Get
    End Property
End Module
www.nxjournaling.com
