NX11 - different part name/description in assembly collumn
Bill Helm
Automotive
ES
Dear All,
I've been looking about this issue without success.
I have the same part (.prt) file
Is there any way of, while keeping the part file name, give a different "name" inside the assembly?
For example, I have a part file 015.prt but inside the assembly it appears several times and I'd like it to appear with different names (015_01; 015_02; 015_03; etc..).
Thank you.
Yes.
In the assembly navigator, with a right click on the component, you can go to the properties menu.
In there is a tab where the component name is mentioned (by default the partname when added to the assembly). There you can change the name of the component.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
Thanks a lot NutAce. Problem solved.
