Sorry I never replied cowski. I use to get emails when there were replies. I dont seem to lately so I never realize someone replied until I come back in to look.
I wish I would have seen this. lol I worked for days trying to figure it out. Finally I found some code where someone did what i needed with dimensions. So I spend a day trying to manipulate that to work with notes. I finally got it to work, but seeing this would have saved me a lot of hassle and time. lol
The good news is I am sure I must have learned a little more in doing it. lol This is the code I ended up with if you're interested. I am sure it could be cleaned up and made better. Once I even got it to work I wasnt messing with it. lol
How do you guys get your code to show up in a lighter background in these posts?
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpenUI
Module Module1
Sub Main()
Dim theSession As Session = Session.GetSession()
Dim theUISession As UI = UI.GetUI
Dim workPart As Part = theSession.Parts.Work
Dim lw As ListingWindow = theSession.ListingWindow
lw.Open()
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "journal")
'change excelFileName to meet your needs
Const excelFileName As String = "S:\Buttons\Journals\test\Book2.xlsx"
Dim row As Long = 1
Dim column As Long = 1
'create Excel object
Dim objExcel = CreateObject("Excel.Application")
If objExcel Is Nothing Then
theUISession.NXMessageBox.Show("Error", NXMessageBox.DialogType.Error, "Could not start Excel, journal exiting")
theSession.UndoToMark(markId1, "journal")
Exit Sub
End If
'open Excel file
Dim objWorkbook = objExcel.Workbooks.Open(excelFileName)
If objWorkbook Is Nothing Then
theUISession.NXMessageBox.Show("Error", NXMessageBox.DialogType.Error, "Could not open Excel file: " & excelFileName & ControlChars.NewLine & "journal exiting.")
Exit Sub
End If
objExcel.visible = True
objExcel.Cells(row, 1) = workPart.FullPath
dim noteText() as String '= myNote.GetText
For Each myNote As Annotations.Note In workPart.Notes
row += 1
Dim draftingNoteBuilder As Annotations.DraftingNoteBuilder
draftingNoteBuilder = workPart.Annotations.CreateDraftingNoteBuilder(myNote)
objExcel.Cells(row, 1) = draftingNoteBuilder.Text.GetEditorText
Next
'objExcel.Quit()
objWorkbook = Nothing
objExcel = Nothing
lw.Close()
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image when the NX session terminates
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
'----Other unload options-------
'Unloads the image immediately after execution within NX
'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
'Unloads the image explicitly, via an unload dialog
'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly
End Function
End Module
Either way, I am going to give the code in the link you left a try as well. I appreciate the help.
