Hello
Using master model concept I am trying to add attributes from the model to the both the drawing border and provide the option to include model/border attributes in a note. For instance, the drawing border is populated by DWG_TEMPLATE_COMPONENT_NUMBER on creation. Later (optionally) I want to be able to use the same attribute in a note. When I reference this attribute in a note I get [COMPONENT_NUMBER] to appear, not the value of the attribute.
Thanks in advance for any help you can provide.
