NX1872 - Closing an assembly
Kenja824
Automotive
Nov 5, 2014
950
I cannot help but believe I must be doing something wrong because I cannot believe NX would be this ridiculous.
We have two of the same assemblies open, but one is a latter revision. What we try to do is open them both fully and then close the older one. That will automatically close all the common parts in the newer assembly, leaving only the changed parts open.
When I try to close the older assembly, it will always give me a message saying certain parts are modified (even though all I have done is open the files). When I close modified, it only closes the modified, leaving all others open still. So I finally closed assembly. When I expand the older assembly, there are many parts still open. I close all of those and expand them and there are more parts still open.
It seems ridiculous that I cannot just close assembly and have the entire assembly close even if it has been modified (somehow without doing anything to modify it).
My guess is there must be a setting that allows me to close all parts in a particular assembly even if they have been modified. Just to be clear, closing all parts would close both assemblies and the main file. I only want to close all parts in the older assembly.
What am I doing wrong?
Ken
My brain is like a sponge. A sopping wet sponge. When I use it, I seem to lose more than I soak in.
I'll just weigh in and say that I'm surprised you can open more than one rev of a part at a time. I didn't know you could do that. I suppose there must be a setting to allow that but, to be honest, I would think the risk of something getting messed up would be too great.
Has that ever worked in NX for you before?
Mike
Yes, I do it quite often. There is a setting in Customer Defaults that allows you to turn on the ability to have two different revisions of the same file open. I cannot remember where in customer defaults it is exactly.
Its not really dangerous because both revisions are released and we cannot make changes to them.
It can get confusing, as sometimes if you are not careful you can be looking at the older rev and make changes to your file according to the older one instead of the updated one.
This makes me realize I may not have clarified something in my original post right.
UPDATE FOR CLARIFICATION!!!
We have one file open and inside of that file we have the two different revisions of an assembly added as components. We update our drafting according to the latest assembly. So when we do an update, we add the new revision of the assembly and compare them and make the necessary changes. When we are done, we get rid of the older assembly.
Ken
@Crocostimpy,
If you want to turn on that option, it can be found at: CD -> teamcenter integration -> general -> multiple revisions -> enable multiple revisions
www.nxjournaling.com
Appreciate the tip cowski but that's locked by my company. I'm not sure I'd want the ability anyway.
Mike
