NX1892: Is there any document on comparison on Product Interface and Wave Geometry Linker
80
Hi ,
Is there any document which gives the comparison between Product Interface and Wave Geometry Linker on what are the benefits, when to use which etc..
Product Interface is a only process to limit what it is permitted as a wave geometry to link in a part
If you set a face for example as product interface in a part, it will not possible to select other geometry in wave geometry linker when this part is in an assembly
Didier Psaltopoulos
