NX1969 - Import Team Center File Journal
Kenja824
Automotive
I have figured out how to import a team center file into another team center file. Here is where I really suck in VB code. User selection. lol
Would this be terribly difficult to set up two different ways?
1) To allow user to select an existing point where to place it.
2) To allow user to select an End Point where to place it.
In both cases, I would like to add a loop so it allows the user to keep placing new ones to new locations until they click OK or Cancel.
Code:
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
'   Menu: File->Import->Part...
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Import Part")
        workPart.Layers.WorkLayer = 253
        Dim partImporter1 As PartImporter
partImporter1 = workPart.ImportManager.CreatePartImporter()
partImporter1.FileName = "R:\hms_tools\NX1872\Tooling\part\Notes\View_Z.prt"
partImporter1.Scale = 1.0
partImporter1.CreateNamedGroup = False
partImporter1.ImportViews = False
partImporter1.ImportCamObjects = False
partImporter1.LayerOption = PartImporter.LayerOptionType.Work
partImporter1.DestinationCoordinateSystemSpecification = PartImporter.DestinationCoordinateSystemSpecificationType.Work
Dim element1 As Matrix3x3
element1.Xx = 1.0
element1.Xy = 0.0
element1.Xz = 0.0
element1.Yx = 0.0
element1.Yy = 1.0
element1.Yz = 0.0
element1.Zx = 0.0
element1.Zy = 0.0
element1.Zz = 1.0
Dim nXMatrix1 As NXMatrix
nXMatrix1 = workPart.NXMatrices.Create(element1)
partImporter1.DestinationCoordinateSystem = nXMatrix1
Dim destinationPoint1 As Point3d = New Point3d(0.0, 0.0, 0.0)
partImporter1.DestinationPoint = destinationPoint1
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Import Part Commit")
Dim nXObject1 As NXObject
nXObject1 = partImporter1.Commit()
theSession.DeleteUndoMark(markId2, Nothing)
partImporter1.Destroy()
'   Menu: Tools->Journal->Stop Recording
End Sub
End Module
Ken
My brain is like a sponge. A sopping wet sponge. When I use it, I seem to lose more than I soak in.
