Using measure-object set to get the center of mass in relation to the WCS. With the reference CSYS set to WCS the pop up window will show the correct coordinates for the COM in relation to the WCS but when I click OK to send results to the information window the COM will say (WCS) next to it but the coordinates have reverted back to be in relation to the absolute of the file. Is there a setting to fix this? Why would the numbers change when you're just sending results to the information window, it should be the exact same numbers. Seems like a bug maybe.
