PG541
Automotive
- Jan 26, 2008
- 21
- 0
- 0
Never used a FEA solver except for a PE solver just to check a design. Anyway, wanted to build a mountain bike frame and started playing around. I'm using NX3 structures to set up the constraints, materials and mesh. When I attempt to mesh the frame using a tetra 4 or 10 I get to 69% and NX3 goes into a 'not responding' mode. I've tried making all the frame members solid and also a constant wall thickness but get the same results. It will however let me mesh each individual frame member separate, I would think you should be able to mate the meshes together but I can't find anything in the help files.
I can provide further information if needed as to what I'm doing if anyone would like to help. Just thought it would be a fun activity for a hobby.
