dazdog
Marine/Ocean
- May 14, 2013
- 9
I have been using NX6 in the workplace for approx. one year. Although not a requirement of the job, I would like to know a bit more about the animation side of NX. I have previously created animations in Inverntor and Pro-E.
From reading other posts, I have gathered that the new sequences, motions etc can be created in the assembly sequence environment.
However, the problem that I have is hopefully a fairly simple one to resolve.
I am using a fully constrained assembly (I am aware that the constraints can be turned 'off' in the sequence environment) and when brought into the sequence enviromnet, I can manipulate the components as I wish (when the constraints are off).
The question I have is is as follows:
What is the best was to start the sequence so that i can show each component being assembled in the order that the assembly would be constructed? To expand; I would like to start with one base component add other components one at a time.
At the moment I have a sequence that shows a particular component move from it's original position, that component then moves out to a determined size and then moves back into it's original position (2 motions).
I have tried to create an exploded arrangement and use that in the sequence environment. However, although the components seem to be well clear of each other in the assembly environment, the space condenses when I go into the sequence environment.
I hope this is clear enough and any help will be appreciated!
Darren
Mechanical Design Draftsman
Darren
