I'm having trouble putting a slot in a sheet metal part.
First off, the reason I want to use the slot feature is so I can dimension to the center of the slot(aka, add a centerline to the center of the slot) and not the ends.
If there's an easier solution to this then stop reading and let me know what that is.
Also, if by using the slot feature, I still won't be able to dimension to the center, than this is pointless.
I literally don't understand what the slot command wants.
When doing the slot feature, I pick rectangular, ok,
asks for planar placement face. I select the face where I want the slot.
asks for horizontal reference, pick a face 90deg from planar placement.
asks for thru face and even when I select something parallel to the horizontal face. I get an error message asking to pick something parallel to the horizontal face.
makes no sense.
makes no sense.
