nx9 - Assembly Labels
Kenja824
Automotive
Nov 5, 2014
950
This may be a GM made function, but we have a button called Assembly Labels. On a layout sheet where we show the assembly iso, you can use this button to create labels with leaders attached to the components and the labels will call out the components names.
Is it possible to do something like this but call out different attributes? Like the File name and rev number along with a couple other attributes?
Trying to make this more clear, I want to attach a label to a component and have it automatically read specific attributes to that component.
Getting a note to reference an attribute is basic NX functionality. In the note dialog, expand the text input and symbols section then change category to "relationships" (if required). From here, you can insert an expression value, attribute value, or sheet zone into a note.
www.nxjournaling.com
Amazing the simplest things I still learn. lol Thanks. I have never done that before.
