I have created a master model from which all the part, part drawings, and the assembly drawings are derived, Also the master model has been controlled using expressions.
I usually use the following way to update the master model.
Tools - Spreadsheet - Add-ins - Extract Exp - (update the necessary changes) - Update NX Part.
But now my customer needs some pop-up or wizard to do the same updates instead of the above method(Spreadsheet)...
I surfed some contents on the internet and ended up with something called Block UI.
Is it the correct solution for my issue or something else is there for this issue.
