duhulefu
Automotive
- Mar 4, 2015
- 6
Hey all,
I am currently exploring NXCAM and I have a small discrepancy between my setup and the G generated code.
Example: Spot drill operation, tool diameter=3.15mm, surface speed=35m/s, feed per tooth=0.125mm, 2 teeth, sprindle speed=3537rpm, cut feed rate=884.25mm/min.
Now in the post-processed G code, the drilling cycle is initiated with N0060 G82 Z-.9449 R-1.1024 F34.8 M08.
I don't see any relationship between the parameters of my operation and the feed rate in the code. Can anyonehelp me along here?
Thanks a lot!
Thanks a lot!
